how the hell do i mount my radio? as you see here in this picture, there is no bracket to mount it. I've been trying to seach it for days but i cant find any results. Can someone help me out?
What year Civic do you have? Im pretty sure you can buy a piece to fit it to your car, but from what I can tell you can't mount a new radio to that without some modification or aftermarket piece.
First, where is the outer plastic cover for that section? It might have a way to mount your radio. Second, you can buy kits from Metra or Scosche that will usually work.
you dont need a bracket to install a stereo in the lower pocket. All you need is the mounting can that came with the stereo. Put it in, fan out the fin and insert the stereo
Theres a bracket you're missing other than the complete lower plastic piece, trust me, I'm an installer. It's a plastic trim plate that holds the radio and bolts in right where those little white pieces are, the 2 holes above those are holders for that plate. So you need to go to a junkyard to get that piece, if you need any more help give me a holla
