Any luck I just checked everything and replaced the fan switch but mine still doesn't work. I can jump it at the switch so the relay and fan work and I can jump it while the engine is running also no problem. The old switch turns on a 200 degrees F and off a 190 degrees. Do you know where I can find the specs on this part. I boiled it with a candy themometer to get these results. It's 98 civic
