Help!!!!!!!!!!!!!!!!!
ghostwidow
On my way home I got in my car to leave work and started it up and it started making weird noise like the fan was riding on the shroud or something. I check the fan clearance and it's fine. So I went to the store to check my oil and it was low. After I added the oil everything seemed fine until the RPM reaches about 3 grand and it starts kinda knocking or something. When I got home I started to rev the motor a little and I can hear something making noise in the valve cover can anyone help????
HomeGrown
Listen to Static Lullaby
I would check your cam timing. And your timing belt. Sounds like it could be out of sync.
rollinj86
Hit the vtec
same thing happened to my 93 dx with no warning started making that same noise you described and the next thing i knew a piston flew through the engine leaving a whole on both sides of the block which was pretty gay.
ghostwidow
yeah I took the car to the dealer and they told me number 4 rod bearing took a s**t. They are also going to call a inspector out to look at the car to see if they are going to repair it or void my warranty.
