Help
twiztidcivic97
How do i change the headlight bulbs in my 97 civic
I know its a stupid question but i have no clue
2kstreetcivic
Runnin to Redline
First off you want to work on your passenger light first because its easier to change.....both lights are changed the same way but the power steering resevior (sp?) get in the way on the drivers side light so it makes it a little harder...alright..heres what you do...
1. Open the hood
2. Unplug the black box that is sticking into the back of your headlights..that is your headlights wiring harness..
3. Then pull of the black weather seal..its like a big black donut.
4. Next, look at the back of your light and move the metal wire out if its little clip by pushing it in a little bit and moving it out of the way of the clip..you will understand when you see it..
5. Finally after you move the metal wire out of the way the light bulb should just pull out...
6. Just do these steps backwards to put the new light in...DO NOT TOUCH the glass part of the new bulb...the oil on your hand will make your bulb burn out faster if the oil is left on the glass...good luck..hope this helped
anfrey
OG スバリスト
i believe this is in the owner's manual. . .
vi3tboi714
MiLaNo Si
yea, thats hw i changed mines, in the manual
