because i can... and didnt realize it until i lowered it, so get over the fact that i didnt fix the car before buying parts for it, and i never new i needed motor mounts until i was told when the belts were being replacedLOL why are you spending money on all the extras when your car needs serious repairs? And why those lugs w/ OEM wheels?
If there is any abnormality to your suspension at stock height, it gets like ten times worse when you lower it.because i can... and didnt realize it until i lowered it, so get over the fact that i didnt fix the car before buying parts for it, and i never new i needed motor mounts until i was told when the belts were being replaced
Whoa there Killer....because i can... and didnt realize it until i lowered it, so get over the fact that i didnt fix the car before buying parts for it, and i never new i needed motor mounts until i was told when the belts were being replaced
i wasnt the one that bought it, my mom gave it to me before i moved to texas, so im learning as i go with it, and i also just found out yesterday that the oil drain bolt was never taken off, my grandpa had to put some force behind it just to break itWhoa there Killer....
I ask b/c this is common sense. You check over a car before you buy it, then re-check it before you start modding.
naahh dont need to put some effort into the title its short and simple, and can see that someone needs help, so no need for your smartass remarks lethalNice thread title...
You've been here long enough. That's newb bulls***. Put some effort into it.
You have a busted suspension component. Most likely the LCA like others have said. To be honest, you should look it over with a fine tooth comb. I am willing to be that there is more wrong with it than just that.
