Hi everyone from alaska new to CC
93coupeAK
Hi everyone, i purchaed a 1993 honda civic EX coupe about a month ago. Spec 's on car its a auto, 174000 i say because the guy i buy it from had put a D15B7 in it if im not mistaken this car came with the D16Z6 vtec, the car also has a few electrical problems but i got them fixed already. I bought the car for $1200 i know thats way to much for this car but being in alaska my options are very slim so i went for it lol. about a week later i bought a wrecked 1999 civic si for $2000 so my plans are to swap the B16A2, auto to 5speed, and the drum to rear disc brake conversion which i already done. now im about to work on installing the foot pedels then once my new intake manifold come in then i can start on the swap. the intake manifold that was on the B16A2 was damaged due to the car being in a front end collision and dont worry i know the motor works the guy started it before i bought it. thats about it for now but i will keep you guys updated. heres a few pics of the car when i first got it.
By nizmoguy6484 at 2012-06-18[/IMG]
Drum to rear disc brakes.
Put new bumper and installed the 99 si side skirts.
Heres my B16A2 waiting to get swapped
heres my box with ECU, pedals for 5 peed, clutch mc, brake mc and other small parts
engine mounts with auto to 5speed mount
new clutch and flywheel
My rota's slipstream juat waiting on tires to come in i got Kumho Ecata AST and since i live in alaska i have these white rims i have on with winter tires
intake, headers, and exhaust
well thats about it for now ill keep eveyone in cc updated
mymmeryloss
RHD is where its at
Theres roads in Alaska?
Welcome to CC!
:hi:
00siboy
lurkin...
:wstupid:
Its always winter in Alaska...duh.
jk welcome to CC!
93coupeAK
UPDATE got my H&R Sport Springs Lowers 1.8 F and 1.6 R. But next month i will be getting Koni STR.T Street Strut for now im using my stock shocks. Hey mind moving my post to 5th generation thnka you
BEFORE
NOW
By nizmoguy6484 at 2012-06-21[/IMG]
Culberson
condoms prevent minivans
what part of AK? i was stationed in Ft. Richardson for four years! haha good thing you didnt follow the trend around Anchorage and get an Evo or STI! nice build though!
Culberson
haha well if your ever looking for parts i know i always delt with Underground Performance in Anchorage. there right across the street from Merrill Field and they usually have alot of Honda stuff especially B16-B18. there worth a call if you ever need something.
93coupeAK
Update: Just got my skunk2 throttle body 66mm, alt belt, exhaust manifold gasket, o rings/seals for fuel injectors. now its time to start working on my intake mainfold.
By nizmoguy6484 at 2012-07-02[/IMG]
93coupeAK
Update got my tires today so went and got them mounted on my rota's
By nizmoguy6484 at 2012-07-03[/IMG]
My rota's on my car finally
Got my engine and tranny seperated, and engine is on stand going to clean out tranny and get started on changing out the intae manifold and t.hrottle body.
93coupeAK
Update: what i did tonight.
sprayed it down once still need a lot more cleaning but its a start
Got my engine wire harness off now its time to clean it up
Engine half way prepped for cleaning sitll have a few more things to take off
Skunk2 throttle body ready to get hooked up
Old intake manifold off putting my blox intake manifold together i need to get something to remove the studs off the old manifold for the fuel rail so thats why i called it a night going to start again in a few days.
AlaskaB16
DOING WORK!
So i've been reading up on this swap and have a few questions. First, installing the clutch. I haven't looked under the dash but is there a spot for the clutch to mount or will it need to be cut out? This car is an auto as described on the first page so this will be a first for me (auto to manual). I've been going through the searches both here and on google but 99 of 100 threads on this topic result in no solid answers, just people telling this person to search. I'll figure it out, but i'd like to get the tools I may need for that install before hand. I have everything needed to move the motor and such. Done that a dozen times already, just never converted to manual.
My next question. Being that everything for this swap came right off the 99 SI, I only have the harness from the ECU to the engine bay (including the ECU). My questions is, will the 94 coupe auto harness plug right into the 99 ECU or will I need to so some rewiring to make that work? Wiring or creating an adapter isn't a problem, just would like to know before hand.
Other than that, I think that's everything... I'm sure i'll come across a few other questions here and there but the previous owner pretty much took care of all the parts needed to complete the swap I believe (Motor mounts, clutch hardware, etc).
