Hi. Ive got some problems with a Civic ESi 92. It started with a loud clicking sound
Civic ESi
Hi. Ive got some problems with a Civic ESi 92. It started with a loud clicking sound from the fuse box in the dashboard. Ive localized the sound coming from the Power Window Relay according to american diagrams of the inside relay- and fuse box in a Civic 92-93 EX and Del Sol (I doubt that is right?). Everything else seems to match with my box. Civic 4th gen. diagrams shows that this relay is to ignition switch, but the other things are more different than my box.
At the same time the headlights stopped lighting (both low and high beam). The running lights (might be parking lights) in the rear(?) is lighting, and the parking lights in front is lighting.
These two things got to have something to do with each other, because when I pull out the running light relay fuse (nr. 16), the noise is gone. May the "P/W relay" be the running light relay? How can I find a electrical diagram of the dashboard fuse box of an Euopean Civic 92-95? Does anyone here got an ESi and know anything? Or have an explanation or advices?
Thank you!
xxBLOOD88SHOTxx
Surge Master
the wiring will be the same, I doubt they went through the trouble of re-wiring the inside of the car just because it is a european model
Civic ESi
Ok. But how can it then be explained why the relay suddenly doesnt make any noise when the fuse to the running light relay is out? It got to be a connection, dont you agree?
