HID retrofitting
IwantVtec
I have a question when I bought my ej1 it came with these headlights
Now I was wondering can I just take the projector out of the housing and put it in my OEM clear head lights? Or would there be a lot of modification to fit?
JohnS.
BANGARANG
If I'm understanding you correctly, you'll have to pull the headlight apart. It'd be a lot of work. It's easy but it would still be a lot of work.
Why don't you just buy OEM head lights? Or buy an HID kit? Even a plug and play kit should work fine in those headlights because they have projector housing.
IwantVtec
No i mean can I take the projector out of my projector headlights and put it in my OEM headlights
kid2006
Whats the point of taking the projectors out of these and putting in the original headlamps???
lowlife9
how do you know if hids can be used in those projectors not all projectors can be used with hids. and why would you ruin your stock headlights with cheap ebay projectors which those are ?. what you want to do is buy a set of miromoto mini projectors from www.theretrofitsource.com thy bolt rite in no drilling and they are real projectors not that cheap s**t.
knightxrider1
yes you CAN take those projectors out and put them in stock headlights and use them for a retro. But those arent very good quality projectors, so your going to do all that work just to be disappointed that the beam output isnt great. If you started off with better projectors like TSX or S2K's, youll thank yourself in the end. And if its your first time retrofitting, study up on HID Planet.com.
JohnS.
BANGARANG
Oohhh gotcha. I thought you were doing it the other way around lol.
As stated above, those projectors probably aren't good quality. If you want to retrofit, you should do it right. Don't cheap out on parts. The only parts I would cheap out on are things that aren't that important, ie - front lip, shift knob, gauge cluster bezel, etc.
You can go to www.theretrofitsource.com and buy a complete kit from there. All you have to do is hack up your headlight
