high temperature!!!
96blkex
Hi, i´m new here, just have a question, the problem with the temperature is when i drive for like an hour on the highway and stop the temperature goes up and when i accelerate the temperature goes down, but when i´m dirving in the city the car can stay for an hour and never pass the middle. i changed the thermostat and water pump already.
i need help cuz i drive a lot on highway.
98ej8
I LOVE MY GIRLFRIEND
I think there's something wrong with your radiator fans. While you're driving the air cools down the radiator but when you slow down there's less flow of air and your fans don't kick in causing it to warm up. With the car off turn the ignition on and turn ac on and see if the fan starts running. Easy test to check fans.
96blkex
tnks i checked the fans and works correclty, some mechanics said that could be the head gasket or the water pump. But i think that the temperature will go up in the city while driving or parked, if i´m wrong how can i check those things?
98ej8
How high does the temp get?
STEV0
ive had this problem with mine, it only goes up about 2 bars too much, i changed the stat and sensors and they didnt work, it turned out to be the radiator cap not holding its pressure, dunno if this is any help but there a cheap thing to change
96blkex
tnx for ur help, it goes to the top, i never let goes to the red zone, i already change the cap for a brand new and change the resevoir tank too, has new hoses. A "new" mechanic told me that i need to clean the inside of the radiator, but i been flushing it every month and still the same, i been with this problem for like a year.
Daily
Does your car run different when it gets hot? Any sputtering or hesitation? My EK used to get warm then start sputtering and I changed out a $7 coolant temp sensor and the problem went away. I also had to rewire the fan switch (the sensor going into the thermostat housing) the connections were real loose. Just check a few things.
96blkex
tnx i do appreciate your help, my car run the same is and sorry for never mentioned but is a d16y8 with dc headers and ebay CAI, another question where can i buy original honda parts online?
96blkex
tnx, what im gonna do is change the gaskets, full set, so i wanna know what brand will be same or better than dealer, or what do you recommend.
TokyoSkies
Boost Junkie
You've only got some light mods, correct? (you mentioned DC Headers, eBay CAI etc.) Do you drive the car hard/plan to drive it hard? If so, look into Cometic (a bit overkill, but they're great head gaskets).
Abailey21
you may have found your answer already but my wifes jeep had the same issue, when the fan was tested it worked fine, but her issue was the fan relay. check that
young_
out on bail
Felpro gaskets would be fine.
Daily
Felpro gaskets work fine, unless you wanna buy some cosmetic gaskets which would be the best option but overkill.
