home stero
basoccer17
oki bum
i have a question does n e one know much about car subs and amps because i have brought an power convertor and i am able to hook up my amp and subs but i can not get the subs to plug into my home stero....i can plug it into the tv and it works but i want to plug it into the home stero if n e one knows please help me...thanks
Beelzebubba
SubGenius Member
This sounds like a bad idea across the board.
the RCA jacks on your home stereo are 8 ohm and probably full power...whatever that may be. the RCA jacks on your car stereo are 4 ohms and a tiny watt rating.
So you're pushing whatever your home stereo output is into your amp X 2
You can try to use the line outs on the car amp but remember, your home stereo is 8 ohm
J32a2OwnsU
Resident Old Man
not a good idea, you will cook your receiver b/c of the impedence (Ohm) differnce... jsut like beezle said only you arent really putting 2X the power, its more the extra voltage and heat....
TorGa3iGhT
"torga eight"
yeah, i dun think u should do it either...car system is meant for the car...home system meant for home
LowNotSlow
Aqua Teen Christmas Force
if you have a non-powered signal out you can get away with it. You DO NOT want to put a powered signal into your amp, it won't last long.
civic!
my daughter is the s**t.
leave the car stereo in the car...
DaGFTDOne
Car Audio Guru
listen to the name.... CAR Stereo. Now I did have my sub hooked up to my mini system in my room at one time but the mini system is preamped at a peak of 160w, Sub kicked nicely really but if I maxed out the sound level it would shut down
