Honda EG leaking fuel
B18A1
I have a 92 honda eg with a b18a1 swamp with a LSD/GSR transmission, 6 puck clutch, E28 chip.
The problem seems to be when the car is running it won't leak gas, but when I shut it off it begins to leak gas, it's slowly dripping down the driver side of the tank. Any ideas as to what it could be causing it to leak?
I'm guessing its the return line, if it is how do I go about checking the line and really getting in there to replace it.
Thank you
B18A1
its leaking at the seems from the top tank to the bottom.
case closed. thanks for 33 views and no suggestions.
