hondata s300 question
got traction
i rock the sohc
so im running hondata s300 on my boosted d. i was wondering if my tuner could have set it to only run 5psi?? my car currently only runs 5psi. the wastegate i ordered is a .5 bar, but im starting to think that either full race sent me the wrong spring in it, or my tuner set a psi limit. is this even possible?
Matt.
its posible for the waste gate spring. I don't think you can set boost in the ecu. Do you have a boost controller? If not get one, and turn up the boost.
got traction
i rock the sohc
yea, i didnt think my ecu could control boost...sucks that they sent me the wrong wastegate then
93turbo16
The S300 can control boost in the ecu with the right components installed. But you CAN'T turn down the boost, only turn it up from the wastegate spring. So it is probably the wrong spring or you have a leak somewhere.
got traction
i rock the sohc
mike@synapse said:
pull the wastegate apart and find out what spring is in it
just talked to aaron at full-race...he told me spring colors, so thats what ima do next
BuiltforSin
my friend has S300, and his tuner put in a boost cut on his SI.
