How did you mount your IC?
spoolincivic
better than you
Hey guys,
Trying to get some ideas on how to mount my IC on my eg. SO if anyone has pictures of that ic mounted on the car with out the bumper that would be awesome. Or throw some ideas how you did it would be good too. So lets see them!!. Thanks
Evan.
iTrader EVERYthing
spoolincivic said:
Hey guys,
I centered it (with the front grille) and then drilled holes through the frame and brackets on the IC. Then put the bolt through on the backside and double nutted (with a lock washer) on the front side.
--<EM1>--
boosted ftw
same here. but i tached the brackets on for more support on those bumper roads
Evan.
iTrader EVERYthing
Wedling skills do come in handy. If I knew how to weld, I probably wouldve just welded it on (to be more secure), but with just the bolt (heavy grade and lock washers) I had no problems whatsoever. It was on there tight. I think I did two bolts on each side.
AMR Engineering
Just got to the hardware store and get a good sized L braket. There are soo many holes below the front radiator support that you can use. That is how I have always done it, and it has always came out really clean. I wish I had pictures, but a L bracket works wonders ONLY if you have brackets on your intercooler or it is has threaded holes on the endtanks like the Precision Cast Endtanks have.
spoolincivic
better than you
ok did that now i was doing my pipes and it seem that the window washer resivior is going to be in the way. I dont want to take it out at all because i love the thing. Is there a good way to go around it or maybe i differant model resivior i can switch out? Or how about i just make my own? any suggestions would be awesome
Matt.
oh sure... you don't want to take yours out, but you're quick to take mine out and say I don't need it anymore.... ass.
Just do what I'm going to do, cut the neck off and move it on up, then have you weld something to the car to hold it on, lol.
Matt.
oh yea... and use a sock or something as the cap.
stealthy
4 Doors For More Whores
my fmic has two tabs on the bottom as well as a threaded spot up top to mount up to
spoolincivic
better than you
yea i already got my IC mounted and stuff but i want to know how you guys went around the windshield washer fluid resivior with the piping
spoolincivic
better than you
i think everyone is missing the point here, i got my IC mounted already, want to know how to retain washers res. while running ic pipes.
whtcivic93
www.mm-graphics.net
zip ties ftw....:scurred: :oops:
until i cut my bumper/rad support out im rockin the zip ties and no bumper haha..
slowhatch
torque?
i dont think there is a way around the windshield wiper fluid resevoir. i just took mine out.
Evan.
iTrader EVERYthing
I went UNDER mine, with 2.5" piping. It was made crazy y0.
