Yes, similar(or exact) as the door panel. I have a coupe if that makes any difference.TilhasBB said:Friction clips?
Is it like the door panel?
YesTilhasBB said:My question before going threw this endevor is will I see the body after i remove that panel?
96greencivic said:It's just held on by friction clips. You can pry it off easily. Just take your time. I did it when I ran some wiriing. Of course it would help if you take out the seats, but not necessary.
Hmm, I don't remember taking out any bolts. I could be wrong, but I remember it being pretty straight forward.PhntmSk8r said:not quite right... there are a few bolts you need to remove as wel... the lower seat belt bolt has to come out, and theres one other bolt but i cant remember where its at right off the top of my head.
Juss looked at the Helms manual, 2D & 3 door, you dont have to remove that seat belt bolt.PhntmSk8r said:not quite right... there are a few bolts you need to remove as wel... the lower seat belt bolt has to come out, and theres one other bolt but i cant remember where its at right off the top of my head.
That is not a a seat belt bolt, that is the bolt that allows you to drop the back seats and open up the trunk space. To get that out, go to the page about the back seats. Pretty much, juss drop your seats, remove the carpet on the back of it and then you'll see the bolts. Juss unscrew.PhntmSk8r said:just like the manual says...
the lower seat belt bolt (aka bolt c in the manual) has to be removed for the panel to come out, it has been that way on BOTH sides of my civic, and same with my friends civic im pretty sure.
