how much bost on stock rods
kilas4doorsleep
all wide and outside
ok so im planning on building a d16z6 turbo motor. At the curent moment i have as set of vitara pistons. im am curious to how much boost i could use untill i got some better rods.
1999CivicEX
if you are putting in pistons might as well save time and money by putting in rods too :what:
www.tunertoys.com makes rods and they are good 600 plus hp. about 220 I think I had a pair and sold them because I am selling the car
edit:
I mean think about your asking whats the MAX I can run on stock rods. Does this mean your going to run the make maybe not. If you do your driving around with a bomb on wheels. When he says 10lbs He means a good as tune.
What are you tuning safc hack?
I have learned my lesson the hard way when I had a 91 AWD Turbo TSi. I spiked 25lbs on a t3 because I was a jackass. My rod blew a hole in the side of my block the size of my fist.
TiiM iiS l3eAsT
Scamming Piece Of s**t
listen to him^^^^
kilas4doorsleep
edit:
i plan on tuning with uberdata or crome. I really only wana boost about 10psi for now. i just wanted to make sure that the stock rods would hold up for that b/c in about a year i plan on rebuilding the whole block so i can boost about 25psi, but if i can find a set of good rods for 220 or somewhere in that range ill just go ahead and get those to and just do the pistons and rods at the same time.
1999CivicEX
You will need a good tune man. NO half ass tune as you probably know. Just if you going to do pistons might as well be safe and do the rods too
stealthy
4 Doors For More Whores
idk how many times i have to say this, but DONT THROW OUT PSI NUMBERS without knowing what size turbo is being used. its CFM not PSI!! 10lbs on a gt35r is going to be alot more potent than 10lbs on 14b.
get it boys?
1999CivicEX
get it boys?
^^^its true. I was just stating if your going to do pistons do rods at the same time
kilas4doorsleep
get it boys?
ok with that said. Would the correct question have been, what is the most hp that the stock rods can handle?
I also would like to say thank you for that lil bit of info.
stealthy
Yes.
200whp seems to be a good/safe number for a z6 with a GOOD tune.
