Shiznit said:you can build a good setup for under $2000. and its easy to hit 300hp with a b16
hallzsi said:what are some of the parts you would recommend? im new to the turbo thing!
Going-West said:300hp on a b16 is very possible, but not on stock internals. if it works on stock internals, it will work for about a week then explode.
k sweet i plan on taking it to a tune shop after the install but i have to get the money and the turbo first!stolle said:the only real hard part is tuning, everything else is just basic mechanical s**t maybe some welding will be required if your confortable doing it yourself go for it but do a lot research and reading and make sure you have everything to do it right and dont skimp on the engine management!!!!
