So i finally got fed up with the bad radio quality in my 2000 civic ex. I decided to take the antenna apart to see what all was in there, and this actually worked alot.
What You Will Need:
- Flat Head Screwdriver
- sandpaper (i used 2 sanding pads, 1 course grit and 1 fine grit)
- about 5 mins of time
First start out by taking the 2 screws out that hold the antenna plate on:
Once it is off, slowly and carefully pull the antenna assembly out, im not sure if anything could break doing this, i just went slowly and got it out just enough to work on what i needed to. Get about this much out:
Now, see all that orange crusty stuff? Looks like rust to me. Now its time to grab that sandpaper:
Carefully use the sandpaper to get rid of as much of the corrosion as you can. I used the course grit first to get the bulk of it off, then the fine grit to clean it up:
Ah there we go, looks much better now:
Carefully push the antenna assembly back into the A pillar and put the screws back in. Turn your radio on and see if it made a difference, mine made a big difference, well that is until i turn the hids on .
Try it out and tell me if it works for you, im curious to see if this happens to most 6th gens.
Heres 2 quick pictures of my dirty car
What You Will Need:
