How To: 6th Generation Black Headlight Housing (DIY)
anfrey
OG スバリスト
note: this was originally posted by peteex on april 19, 2002 on sho. i do not take credit for this. i am merely getting this information to you.
I finally did it, I woke up this morning and was bored so I decided to tackle this project which I've been wanting to do for months, best part is it only took about 5 hrs. total.
1.) remove your bumper cover and your headlamp assemblies. not difficult four bolts per lamp total.
2.) Heat oven to 200-235 farhenheit. place one lamp in at a time for ten to fifteen min. use a large flat head screw driver and a pair of work gloves( those lamps are HOT!!) and gently pry the pieces apart, it's quite easy if you use the oven because the whole lamp is warm not just one spot. whole process 15-20 min per lamp. then just unscrew the chrome assembly from the lens.
removing the orange reflector is quite easy.
next I masked off the reflector area around the turnsignal. then I cleaned the whole thing with denatured alcohol and distilled water. I the sprayed several coats of rustoleum mettallics black and let it set for 5 min. *(I chose this color since it seemed to be a bit more interesting than just plain black, plus they didn't have the color I wanted in high temp paint, to solve this I did the following)*
I followed up with a wet coat of Duplicolor Clear high temp engine paint. I let it dry for a full three hours as directed
Next I took a tube of clear silicon sealant and ran bead all around the seam of the headlamp. I reinstalled the newly painted housing back onto the lens and push the whole assembly together as best I could. I then put them back in the oven for ten minutes to soften the sealant and was then able to push them together completly. I then reinstalled them and voila!!
I am very pleased with the end result and would recomend that anyone with the time and skill try it. It's really not that difficult. As you can see I didn't try to clear the orange reflectors, but I figured that I didn't have the materials to do it correctly so I didn't actually bother.
not a single thing melted except for the sealant. The halogen bulb inside your headlamp gets much hotter than 200 degrees and therefore your headlamp housing is built to withstand much more heat than that. The sealant dosen't liquify or melt but it just gets really soft and plyable that's why it pulls apart so easily.
I let the housings dry in the sun, I don't know if it made any difference or made it dry any faster, but I haven't had any problems yet and they did dry smooth as glass.
I looked into black when I did it, but decided on the mettalic black because I think it made it a little more interesting, it's not as dark as flat or gloss black but not as light as true 99-00 CTR's.
And just so everyone knows, I experienced no drop in light output, if I did, it's so small that I didn't notice.
v-teced
I didn't do it.
NICE how to anfrey!!!!.......muy bien!....mucho propos!
anfrey
OG スバリスト
peteex posted this 5 days later:
Well it's been about five days with very few problems. I washed my car the other day and my passenger side lamp fogged up pretty bad, I'll have to pull it out and reseal it, I think it's doing this since after I initially put it back together I forgot to put the orange reflector back in so i had to reopen it and forgot to reapply the silicon. They both intially had a little fog in them right after I reinstalled them cause they were still hot from the oven but that cleared up quickly and hasn't come back, at least in the driver's side lamp. The paint brand I bought also came in flat black but had a clear gloss coat to, which is what I used over the regular non high temp metallic black, So I guess you could get the high temp flat and then put the high temp gloss over it. the grill paint might not come out as smooth I got the paint at Auto Zone.
anfrey
OG スバリスト
metallic paint vs flat black paint:
metallic
flat black
anfrey
OG スバリスト
not my work, but i know everyone here's interested :P
anfrey
OG スバリスト
this is how it looks on a zenki (96-98) EK
VTECSOHC02
On The Raod To Twin Turbo
Great DIY!!! Been wondering what type of paint ppl been useing... Maybe I'll try it this coming weekend!!!
Zak8022
damn, that looks nice. thats definately a project i will try during the next few months while i am relatively broke.
anfrey
OG スバリスト
i'm doing this as soon as i get back stateside. gonna go to a junkyard, find some headlights, and get to it.
EK9
CCSC #15 & HID Specialist
great DIY ... props! with great pictures :-D
9civic7
i really like the oven idea. When i did it to mine i just used a blow dryer and it took for ever. Then I went out and got halos anyways but I love the way the jdm style looks
Team 4R
Dr. DIY
oven? hairdryer? you guys are pussies.............. just get in there with a blade and your fingers............
anfrey
OG スバリスト
sorry guys, it's an ancient post from october of last year and the image hosting ran out. i'll reupload the pics once i get back stateside where i have my computer
EK9
you guys read that.. .before saying anything... :lol: he still at Sout AMerica i belive Chili
