wats crossover mean? where do i set it? ive got a 12 inch. and for the gain? how do you adjust it correctly?
obviouslythe best advice you'll get..the gain is NOT a volume knob
cut/copy/paste ftwA crossover filters out specific frequencies.
a Low Pass Filter (LPF) is used when you want to have frequencies below a specific level sent to the speaker (and the frequencies above it are filtered out). This is generally used for subs and mid-bass drivers.
A High Pass Filter (HPF) is the opposite of a HPF. It filters out frequencies below a given level and passes the frequencies above it. This can be used for midrange drivers and tweeters.
A crossover in a set of component speakers has manufacture optimized cross-over points for the speaker set. This filters which frequencies will go to each speaker component.
Actually, I wrote that outcut/copy/paste ftw
yep thats how I always do it.i jsut cranked it up, adn slowly fiddled with my knobs. idk what the hell they were but i would notice how each knob would change the bass. i had it cranked though, so when i had it to my DD volume, it was perfect
(2 12's in a powerbox)
oka. so on my amp, should i set it to low mode? instead of full and high mode? becuase its strictly wired to my subs? and on my deck, pioneer ub5000, i can set the speaker FQ to about 80hz or 100 right? since i really dont want too much bass from them.A crossover filters out specific frequencies.
Most people set the Low Pass Filter for their subs between 80 to 100hz. Then have your speakers pick up from there. So set the High pass filter on your speakers at the same frequency that you set the Low pass filter for the sub. This is efficient since both the speakers and subs wont be reproducing the same frequencies, not will they be leaving any out. Running "full range" means that the crossover will be disabled.oka. so on my amp, should i set it to low mode? instead of full and high mode? becuase its strictly wired to my subs? and on my deck, pioneer ub5000, i can set the speaker FQ to about 80hz or 100 right? since i really dont want too much bass from them.
