Just had a half day at school and decided that instead of going to sleep i would finally test this DIY on making citylight socket holes in the OEM USDM honda headlight assembly.
Applicable Years: 96-00 civic (ALL)
Difficulty: 4 out of 5
Estimated time: 3hours
Required Parts:
-99-00 oem headlights (not sure if aftermarket have back template)
-2x 194 bulbs
-2x city light sockets
Required Tools:
-Dremel with SMALL drill bits
-usable oven
-prying tool
-windex
-rags
STEP 1:The beginning of this is the same as doing DIY CTR headlights. I am not going to do another step by step for it when you can just search.
NOTE: Don't try getting around try getting around the first step because you WILL get drill dust inside your headlights and you will have to open them up to clean them anyway
STEP 2: Use a marker and mark a dot in the middle of the citylight spot. Drill it out and move outwards until you reach the border.
NOTE: Don't drill too close to the border or the socket may fall right in when you install it
STEP 3: Drill the BACK of the reflective part of the lense CAREFULLY. Use the border of the citylight spot as your guide. Don't go fast or you will mess up.
NOTE: Do NOT drill from the front of the reflective part because you will not know where the citylight hole is and mess up
STEP 4: After you shaped the reflective part of the light from the back, drill the front of the reflective part of the lens to round it off. Sorry, this was the best pic i could take
NOTE: Take your time doing step 4 because if the dremel slips and drills the surface of the reflective part, their is NO way to correct it.
STEP 5: Use a rag, windex, or a cleaner of your choice and clean the drill dust off the lens.
STEP 6: All the hard word is done. Just slip the citylight socket into the slot and glue/tape/silicone the socket in.
NOTE: If you can, make sure the light in the socket works so u wont have to take it back out.
STEP 7: Put the headlight back together and you are done.
edit: pics added
Required Parts:
-2x 194 bulbs
Required Tools:
-usable oven
-prying tool
-windex
-rags
edit: pics added
