How to: DIY OEM radio lighting in a 6th gen (96-98)
wfw12
I was tired of looking at my stock white lighting from the OEM radio so I got to thinking about if I could change the colour and this is what I came up with. I started with a 96-98 but it might be able to be done with a 99-00 if your looking for the Si look.
Time needed: 20 min… depending on how many times you have taken apart your dash.
Tools: Small Phillips screw driver, 1 paint brush, 1 little jar of paint (your choice of colour)
Skill level: 1
Total cost: $0
Start by removing your factory radio. There are DIY’s so im not going to cover that, just search if you don’t know how.
Remove the screw beside the harness plug
Remove the screws on both sides of the faceplate
Pry off the cover starting with the area marked “open”
Remove the cover from the back
Gently remove the faceplate from the main housing
Pry the circuit board from the faceplate, the volume knob will want to stay on so you have to force the curcuit board out slowly
Remove the blue “condoms” from the LED’s. there are 6 in total
Lightly paint the LED’s with the paint of your choice, I chose red
Reassemble in the reverse order. Put the radio back in your car, put your dash back together and admire your work.
Billy.
Has returned ;-)
turned out pretty good. could you not just replace the bulbs instead of painting them?
sticky worthy IMO
defvayne
Set This World On Blaze!!
looks good. Should of done the climate control too. Its only 2 bulbs.
Matt.
you could prob replace the bulbs, but thats probably a lot more work.
d00dle
nice =) I feel bad u guys stuck w/ stock radio (it hooks up w/ security system, am i correct?)
dyce590
True Life:I drive a Civic
if u upgrade ur radio it should b common sense to upgrade ur alarm as well. that way they will both act independently
wfw12
cant replace the bulbs since they are LEDs, im sure it can be done but that requires re-soldering them in.
i was going to do the CC but i didnt have the bulbs to replace them since i think the paint would chip off from the heat
