DaggWood
I just bought a 1996 Honda Civic EX last Mont.
The plastic latch to pop the hood was broke off, but I was still able to pull the cable with pliers.
It's a pain in the ass to not have a release handle.
I was thinking to get a new Cable release handle from a scrapyard but what if it break again...
So i decided to make one that would not break somehow.
This was my solution to the problem. A T-Handle Tap Wrench.
Easy to install, nothing to remove in the car, don't look that bad, will not bread again.
To install it simply remove some plastic at the tip of the handle cable.
Cut the T-Handle Tap Wrench handle to the length you want. I use a dremel to cut the handle.
Insert the T-Handle Tap Wrench on the tip of the cable handle and tight the T-Handle Tap Wrench around it.
That's all there is to it, simple and solid.
