My friend dropped something down the vents that clear the windshield(The very front long skinny ones) and I want it out. I own a 1995 Honda Civic EX coupe automatic. What do I need to do to get that out?. Thanks in advance.
Here are the locations of the dash mounting bolts.....You will need to drop your steering wheel, and pull your radio and climate control....Just let it go man......
Edit: OHH and I just remembered if you use my referal code I get $20 off my next order please do if you don't mind. Your Crutchfield Referral Code: p5f5a-4hy43-psc27
Also, if you plan to buy from them, make an account first and sign up for their rewards program. Its worth it.
Deezy, I actually just spent the last 4 hours trying to remove my dash. I got all the bolts out, but could not figure out how to get the CC buttons off the steering wheel so I can take it off. Also, when pulling on the dash, the SRS panel above the glove box on top looks like it is holding it down.
Matt, I will check them out, Im not sure when Im buying the speakers though so dont sit around and wait for that referral.
you don't have to remove the steering wheel, you just have to drop it from the dash. There should be like 4 bolts holding the steering column up. Not sure exactly as I never removed a civic dash, but other cars are all similar to each other in this case so I would assume it is the same.
