how to get rid of da check engine light!!!...please help..
lazykidsi
does anyone know how to get rid of the check engine light in a 97 honda civic dx hatch...?? : =)
defvayne
Set This World On Blaze!!
pull out your "hazard" relay for 10 sec. and then put it back on. It should be located by the case near the battery.
baby99si
N/A project has begun....
fix it or get electric tape and cover it up=)
civic1582
CCSC #86
fix the problem that's causing it
lanojp1
unplug ur battery for like 10 minutes, then plug it back up...
civicex23
Yes, I know she's hot!
Disconnect battery first then remove the main fuse from fuse box. The reconnect fuse and then battery. Works for me.
EXcon279
yea mine comes on every time i hit my govorner. but all i do it unscrew the battery fuse then put it right back on, and it works.
DirtyD
you're all wrong except defvayne
to reset the ECU, unplug the battery for 5 minutes, plug it back in and le the car idle for 5 minutes
but to really get rid of it, read the code and get it fixed
EM1_ProJect
Yeah...it's boosted
this might sound REALLY noob like...but how do you read the codes because nobody can find out what is wrong with my brothers and the CEL has been on...he bought new stuff that was recommended to fix it and NOTHING.
Noeladams
Keyboard Cowboy
I agree,,,,,
I wouldnt be surprised if it was a bad o2 sensor or something!
DirtyD
You need to read it with a diagnostic reader, you can buy your own OBD II handheld code reader from any number of vendors for under $200.
xivera
insert witty remark here
This is what you do to read CEL # code.
Get a paperclip, put it aside and, start removing your passenger's kick panel so that you can get to your ecu and the diagnostic circuit. Follow along here... http://www.c-speedracing.com/faq.php. (This link is posted in the archived How-to's.)
Good Luck... Hopefully, it just concerns something small like O2 sensors....
EM1_ProJect
Yeah...it's boosted
maybe i'll just bring it to the local shop to read it for free...then ill do what i gotta do
