HOW TO: gsr gauge cluster install in EG & EK
GSR cluster install modSearched info provided by iselfdevi
Ok, ok here it is. Everything you need to know to install a full working gsr cluster into a the eg or ek civic. I am NOT taking any credit for the information, but i am taking credit for all the research i have done in acually doing this mod. As far as wiring goes, about 80% of all the wires are the same color for both gsr and civic. So, that makes the wire much easier for you.So, have fun and a big THANK YOU for those who provided the info and all the write-ups for this awsome mod.For those who provided the info and the write-ups please email me at iselfdevi@verizon.net so i can post it. For all respect.
LINKS
94-98 gsr cluster into 92-95 civic with pics and wire color chart
gsr cluster into 96-00 civic with pics and wire color chart
FIRST THINGS FIRST
The gsr cluster is NOT a plug-and-play install. I heard you can just repin the wires on the 96-00 civic, and if that true then go for it. Just becareful not to pull the wire from the metal pins. If you dont want to repin then you must get a gsr cluster with the harnesses to do this mod. The stock civic harnesses must be cut off so the gsr harnesses can be wired in. There is some cutting involved in this mod, but it's nothing to major. The hardest part is the wiring process. I suggest you solder all the wires because solder never comes undone unlike butt connectors. Solder is the BEST connection. I have been installing radios, amps, and alarms for the past few years and trust me solder is the way to go.
TOOLS
The following tools are needed;
1.Soldering iron
2.Solder (very small gauge)
3.Wire strippers
4.Wire cutters
5.High quality electrical tape (3M is perfect)
6.Print out of the wire color chart----->Wire color chart for 92-95 civic ----->Wire color chart for 96-00 civic
7.Dremel (never leave home without one!!!)
8.Philips head screwdriver
WIRING CHARTS
Quick link of the chart below but I cleaned it up a bit and made it printable!
and here is the wire color chart that are going around the web for the 92-95 civic. i am not taking any props for this!!!
Integra Blue Left Side Plug (13 pins)
1. BLU - Tach signal
2. GRN/ORG - Check engine indicator
3. YEL/RED - Oil pressure switch
4. -not app
5. WHT/BLU - Charge indicator
6. -not app
7. YEL/GRN - Coolant temp
8. BLK - Ground
9. RED/BLU - Cruise control (if you have cruise)
10. YEL - Hot
11. -not app
12. PINK - Maintenance (not used)
13. -not app
Integra Right Side Blue Plug (16 pins)
1. GRN/RED - E-Brake signal
2. RED/GRN - High beam
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. -not app
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
9. BLU/RED - ABS (not used)
10. GRN - Trunk switch
11. ORG - Vehicle speed sensor
12. -not app
13. BLU/WHT - Low fuel (not used)
14. YEL/WHT - Fuel gauge
15. LGT. GRN/RED - Door switch (not used)
16. RED/BLU - Seat belt
Civic Left Side Grey Plug (12 pins)
1. YEL/WHT - Fuel gauge
2. YEL/BLU - Vehicle speed sensor
5. WHT/BLU - Charge
6. YEL/RED - Oil pressure switch
7. -not app
8. BLU - Tach signal
9. -not app
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
Civic Right Side Grey Plug (10 pins)
1. RED/GRN - High beam indicator
2. GRN/RED - E-Brake signal
3. -not app
4. -not app
5. GRN/ORG - Check engine indicator
6. BLK - Ground
8. YEL - Hot
9. GRN - Trunk switch
10. BLU/WHT - Seat belt
PICS
96-00 (ek) civic
92-95 (eg) civic
LINKS
FIRST THINGS FIRST
TOOLS
1.Soldering iron
3.Wire strippers
4.Wire cutters
WIRING CHARTS
4. -not app
6. -not app
8. BLK - Ground
10. YEL - Hot
11. -not app
13. -not app
5. -not app
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
12. -not app
5. WHT/BLU - Charge
7. -not app
9. -not app
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
3. -not app
4. -not app
6. BLK - Ground
8. YEL - Hot
PICS
96-00 (ek) civic
92-95 (eg) civic
