Aight so before i start. I dont want to hear how this isnt the actual JDM way or this isnt how its supposed to be wired.. This is the way i did cause thats the way i wanted it.. With that said
First materials
Screws
Some type of metal elbow. (i found one in my basement)
Hazard light ( you can find similar lights like this at auto zone for about 4 bucks)
Wire
Electric Tape
Lets get started
Remove your rear bumper.. Its actually quite easy
Now the Raybrig fog's have a Black housing and mine had a white so i painted mine black... Black flow much nicer with my car anyway
I suggest we start the wiring first. We are going to tap into the taillight. This is where some of us can go seperate ways. I chose to have my fog come on with the parking light, and blink alternatively with the passenger side blinker (since the fog is on one side.)
Remove your tallight
Take a look at what youve got. We are going to tap into the parking light (RED Wire) and tap into the turn signal which is (green/yellow)
Do not tap into the taillight though.. I just showed you that for reference to the colors of the wires.. Tap into the harness right as it goes into your trunk.. This way you can remove your tallights freely whenever you want to (as opposed to removing the fog along with it.
Here is what it should look like once you tapped into those two wires with two long wires that can touch the floor. Please note my shity tape job
Hide and tape the wires behind the bumper support
Now here is the tricky part.
Now in the picture above you can see there are two holes on the far letf and far right that go straight through the housing. And dead in the center there is a wire that goes from in between the bulbs to the outside of the housing.
We are going to link the two bulbs together so that they come on together.
Then take one of the wires from behind the bumper suport and bring it into one of the holes. Wrap it around the metal that keeps the bulb in place. In order to link the the bulbs together take a small piece of wire and join the two pieces of metal that hold the bulbs up.
Now to complete the circuit take the other wire from being the bumper support and join it to the already existing wire that comes out of the center of the housing.
aight i wanted to get as close to perfection as i could cause i hate to half ass things that other people will need
so here is the long clean way to do it
We are going to drill a hole for the wires to go directly through the bumper instead of hidden and taped under the bumper
Now we have to get back to the mouting kit.
Here is what we had before................Yuck
I took that same very piece and went to work.. I sanded it down using my dremel and sanding bit..
Then i heated that b***h up on the stove fire., got a hammer and cinder block and went to work flattening and shaping the metal to conform perfectly to bumper. The trick is to hammer it WITH heat. That will make it more malleuable (sp?)
Here is the end result of the mounting piece
Now lets mount this mother
(VIDEO ADDED)
http://media.putfile.com/My-car-blinking-and-talking
First materials
Screws
Wire
Electric Tape
Lets get started
(VIDEO ADDED)
