How to remove this?
bmatthew96
Hi guys. Just bought and SI and am very excited. It had a turbo in it that im trying to remove and has a oil line (don't know if its a return line or not) that goes into the block. Looks like there is a sensor there two. I don't know what its is. If any of you have an idea let me know. I was thinking unscrew it before the sensor and put a screw in. What do you think? What is that sensor? Thanks guys haha
AlaskaB16
DOING WORK!
Oil feed comes from the block, oil return goes into the oil pan. The pic you posted looks to be the oil pressure probably feeding your turbo.
xxBLOOD88SHOTxx
Surge Master
oil pressure sending unit
remove sending unit, last couple I used a small cresent wrench, then remove line
why are you removing the turbo setup
bmatthew96
I want to convert it back to stock and the turbo is really old. might turbo in future but don't care to right now, I just want it running right and healthy. Anyways, so are you saying I remove the oil line from sensor, remove sensor from block, and then put a bolt into the block?
AlaskaB16
DOING WORK!
Remove the feed line and put the sensor back in. The sensor belongs there, not the turbo feed.
bmatthew96
Okay cool, thanks a lot guys. Ill start another thread soon to show the new car haha cant wait till its finished!!
bmatthew96
Im a little confused, do I thread the sensor out of that coupling that holds the oil feed line and sensor, and then take the coupling out of the block and thread the sensor directly into the block or do I unscrew the oil line, with the sensor and coupling still in the block, and just put a screw in there (where the oil feed line was) to stop her from leaking?
CO671
Before you revert it back to stock, what're the mods done to it?
Is there an aftermarket ECU? Injectors? How big is the exhuast?
mc360
boosted hx
yes there is probably a T fitting installed, you must remove the sensor from the T then remove the T from the block and install the sensor into the block. the sensor is just a dummy oil pressure light which you really dont need if you just want to plug the hole
