How To: Replace a light switch
Jordan_n
No fun unless ur Dragging
this is my broken light switch, it stopped working then decided to twist off.
first start off by removing the paneling around the switches, the clips usually end up breaking. I ended up breaking one of the clips. Pull off the panels and then turn your steering wheel so it looks like this
next unscrew the small gold screws
then use a flat tip screw driver to help remove the plugs in the back
the switch slides out left but it snaps into place so when removing it be careful to not accidently break the switch when it flings out.
mine was melted oddly also :???:
the new one slides right back in and snaps into place
snaps the plug back in put the screws back in and put ur paneling on
and it looks brand new like this
wetcmonkey
can you make them shorter? i would like that actually.
jdmem205
Even tho I used this for the wiper switch it still helped me out great write up!!!!!!!!
