How to get rid of SRS Light Troubles
This is only for people who accidentally triggered the SRS sensor, or got new airbags, dont erase it unless u have working airbags, dont want anyone getting hurt now, haha
Well first of all, u shouldnt erase the memory until u figure out why its on or off. Once u figured it out, erasing it is a snap. i have a 00 civic, but if the connector fits then it will work for any civic year, cause the connector i got was from a Honda Odyssey.
the hardest part is finding or buying the service connector, your dealer should have it ECM/PCM service connector part #07PAZ-0010100, dont worry its like $4. better than dealer charging $120 for an hour to do the same thing. i think they might also have some info at www.jdmfan.com. heres where i ordered mine, http://www.handa-accessories.com/odymaint01.html
1)Locate the yellow memory erase signal connector (for 99-00) its upper right corner side of the fuse panel. (for other application on location, check your repair manual)
2)make sure ignition is off, then connect the service connector part #07PAZ-0010100
3)dont start the car, just turn key on
4)the light should go on for 6 sec. and then go off, soon after, within 4 secs. remove connector
5)then the light should come back on, within 4 secs of it coming on, reconnect the service connector
6)the light should go off, then within 4 secs., remove the connector
7)if it was successful, SRS light should blink twice
8)turn ignition to off, wait like 15 secs
9)turn on again, SRS light should be on for 6 secs, then off
remember i tried this like 4 times before it worked, so dont get frustrated the first time if it didnt work
if i missed anything, sorry for that, tried my best, this sucker is kind of confusing to explain
