How to tell Fuse number to harness
JDM_SPEC_SI-R
hey guys i am trying to do some tricky wiring for a rear wiper motor.
does anyone know how to locate what fuse number goes to what harness number under the dash?
for example: fuse 3 goes to harness c501 wire color red...
i need fuse 3 and thats it i think and maybe fuse42 with harness number and color under hood
thanks
Wax Hands
Smell my finger
Get out your service manual or Chilton and start looking at the wiring diagrams.
You will be able to easily decipher what wire color combo that connects to each particular fuse.
JDM_SPEC_SI-R
lol .... really? cause i have been searching for hours through manuals and whatnot and have found nothing.
JDM_SPEC_SI-R
ok so the wire color is green and the only green wire is on the icu. now the wiper switch has a green wire going to the fuse as well as the wiper motor(green wire). how should i splice the 2 wires into the icu green wire? just piggy back style? splice 2 green wires together to get one then splice to one green wire on fuse box wire?
on the diagram both wires are going into fuse 3
also on the switch, it has a black wire wich is a ground. on the diagram it doesnt lead anywhere, it just stops, can i ground this out anywhere?
-same on the motor ground??? but im sure the ground for the motor harness that meets the floor harness is grounded out, because there are no more terminals left....
and on the washer motor for the fluid, it has a green black wire that connects to the same wire color on the switch, but then there is a black wire that grounds. doesnt say where... is it possible to ground this anywhere?
