Originally posted by td-civ
dont do it for the money you can do gsr and make more power the motor is a pain you need to change to many things to do it and the car will drive like s**t
BS!!!!! More power? Change too many things? Drive like s**t? No, no, and no. Stock to stock the h22 (23) (200Hp 161Trq ) has more hp and torque then the gsr (180Hp 126Trq ). So i dont know what your talking about there.
Change too many things? Have you ever done the swap? Or are you going off of what you've "heard?" Sounds to me like your going off of what you've heard. I've done it and there is NOT that many things you have to change. The longest and most time consuming part is the wiring. But what are you talking about change?
Drive like s**t? Again, what is your basis for this statement? I dont think its first hand experience thats for sure. Comeing from first hand experience myself i can tell you It does NOT drive like s**t. Yes you have to upgrade your front springs to handle the additional weight of the h, but other then that, it drives great.
The only difference between the h22 (Si Vtec) and the h23 (Si) is the 23 has no vtec and the 22 does. Other then that they are completely identical.
Frik - i can give you a better explanation of the things you need to do if you need it.
td-civ - Dont post about stuff unless you have first hand experience and know what your talking about.
