i got a question.... please help me asap!!
tharealjdm
i got a 2005 rsx type s
i know, im sorry its not a civic....
ok i took my steering wheel off and put aftermarket hub and wheel on...
????? how do i get the airbag light to go off ??????
please help me asap!!!!! pm me asap or respond!!!
wannabe
law abiding smog tech
hhmmm. bump for an answer. i have the same broblem in my ej7. i got a non-srs ek4 wheel and i dont know how to make the srs warning light go off. i unplugged the fuse for the srs system from the fuse panel but the light still wont go off.
EDIT: why is this in the parts for sale section? :what:
mort tek
yo put the stock one back go do ur inspesion then changed again thats all u need to do....
tharealjdm
i tryed that and the light stayed on.. someone told me to get a 2 ohm resister or somethin and it will make the light go off ? i got no clue... i just dont like ghetto stuff done.. i dont wanna jus take out the bulb.. there has to be a way to do it legallly...... please help
sorry for bein in the parts.. i figured id get a answer faster this way....
blueline
JDM Jerzy Domestic Market
Put your OEM steering wheel back on and forget about it.....that way your ass can be saved if you get into an accident.:twocents:
I would think removing the bulb would be the easiest thing to do. If you've changed to a non srs steering wheel, who the hell cares how legal or illegal things get now, it will never work again anyway. Just write the system off and pull the bulb, problem solved.
Cod Man
1.7 60'
yeah, just pull the cluster out and you'll be able to see what bulb it is
JDM-JNKY
In JDM We Trust
humm wrong section but you can always take the bulb out your cluster like the others stated.
tharealjdm
thanks for the help...
what do you mean write the system off ? i gotta take it through inspection.. i knew i should have waited
i put the stock wheel back on, and the light stays on now.. the 1st time i did it.. it went back off, now it just stays on..
anyone know how to take the cluster out of a rsx ???
JDM-JNKY
In JDM We Trust
never done it before but just take every screw you see around the cluster off :what:
tharealjdm
thats the thing, there isnt any.. lol i guess i gotta mess with it and try to figure it out.. someone told me get this lil 2 ohm thing.. but i dunno if that will fix it cause i think its the srs thing behind the wheel that is messing s**t up for me
JDM-JNKY
In JDM We Trust
Some cluster's have lil clips you have to almost pull them off with alil force. Yea mine was like that too when I put my hub and quick release on so I just went in there and pulled the bulb prob solved.
tharealjdm
yeah.. i think ima do that.. im just gonna go pay 100 for a sticker and call it a day i guess.. lol so now im gonna try to pull the bulb them.. thanks for the help...
xxsenceo89x
aka superman
just remeber its gotta pass visual inspection also. if they see a missin airbag they might give you s**t about it.
cant you jump 2 wires and it goes off?
91SIHatch
SOHC IT
most of the time they sell a plug and play harness that runs a open circuit or closed circuit i cant remeber, but it takes the air bag light off and sends that message just continuously through that harness, kinda like a mil eliminator on a mustang so it doesnt trip the 02 sensor, its like a blocking harness thats what you will need to do it right.
kaace
I'm getting there...
did you reboot your car? unhook the battery for a few then hook it back up...works for my computer and PDA... =)
mlassek
that wont work. put all your stock s**t back on and if the light is still on your are going to need a scan tool to erase the code (that is if you didnt f**k anything up) . why do you wanna put an aftermarket wheel on? isnt the stock rsx wheel sporty enough?
aaren99
Change everything back to stock, go to any good shop that does diagnostic work and they can reset for about 30-40 bucks. Messing with the srs system is not a good idea especially if you ever have to sell your car.
