i have 97 civic dx need help with wiring pls!!!!!!!!!!!!!
streetscars88
i have 97 civic with dx and also i got motor swap out and changed into b18a1 obd0 motor with cable tranny and i need help with wiring and i have ecu jumper with pr4 ecu and i still have my stock ecu too and i need help with all the wiring diagramn for tranny and motor but i did some plugs convertion too but beside my motor wont start with no spark but i got gas and i belivied it coil went bad but i still have lots of wiring to do i need help with wiring i hope you guy help me
freshrex
get a obd1 dizzy and ECU and get a hydro tranny. should save you alot of time and headache. the swap pretty straight foward. if you go obd1 i believe the only thing you have to do wiring wise is the 3 wire to 2 wire IAVC correct me if im wrong.
streetscars88
but witch one i could have dizzy obd1 but i have obd0 ecu and obd0 dizzy and but i had cable tranny hook up but wiring not yet hook up my car is auto and ecu is auto it came with engine and tranny
streetscars88
and i had obd0 dizzy hooked up and there no spark coil got so hot and still got no spark i belvied it have power to dizzy and i have stock wiring hardness on engine bay and got fuel injection hook up and dizzy hook up alt hook up i want to leave auto tranny for now until i get more money to spend for manual tranny
freshrex
you need to get a hyrdo to cable conversion if you want to use that tranny. Our cars come stock with hydro trannys which are better IMO and just get a obd1 PR4 or P75 ecu and dizzy it'll make it so much easier.
streetscars88
and my car came with auto when i first got the car and it was stock d16y7 then engine took a shot so then i convertion to b18a1 with auto tranny
streetscars88
so do you know anything about the wiring on auto tranny 0bd0 with my stock hardness i know i gotta convertion the plugs switch out
freshrex
same as you got lol b18a1. I would suggest doing as much research as you can before attempting to swap engines and messing with wiring. that way you know what to do and what not to do
freshrex
ok so do you know anything about atuo tranny wiring so i can have it hook up snice my car still stock atuo wiring
Not really . I dont f**k with Autotragics lol but before you do any wiring you still need to get a hydro to cable conversion if you want to use that tranny
streetscars88
my car is auto and i have auto tranny in the car with b18a1 now i got cable shifter hooked up and axle for it it been done but i need to know about the wiring on auto tranny
