i keep thinking about this...
antivic
its all about VTEC!
right now i have 13inch steelies :lol: and the car is dropped like...an ankle off the floor...and i wanna buy 16 inch rimzos do i have to get my car higher? or will the rims make no difference? i can't get this out my mind...
hatch2000
i don't think you woiuld have to raise it. I have 17's and when i switch it from stock rims to those it doesn't really make a difference. The stocks are a little lower, but it shouldn't be that much different. oh yea the 16's might scratch the wheel well if you lowered your car that much.
slambed_civic
youre goin to have a problem with camber, so yes raise it up a bit
antivic
its all about VTEC!
thank you =] i was afraid of the rubber touching the fenders...but i guess theres alot more to it ;) thank you again =]
slammed_93_hatc
NoR*CaL knowledge b***h
http://www.honda-tech.com/zerothread?id=811268
read that, and just because you increase rim size doesn't mean you willl increase the overall diameter of the wheel/tire combo. when you get the 16inch wheel most people will go with a smaller tire so that they stay close to or right on the same size stock diameter.
only issue you could have is with the rim being to wide but i doubt you will be purchasing a 7.5 inch wide wheel
Je
the white hatch
if that did havppen you could just roll your fenders
slammed_93_hatc
this along with what was said right below it are toatlly contradicting statments. camber does come from lowering you car, but if you want to go low and have the tire inside the wheel well then you need camber, if you didn't have it then your tire would hit your fender. i don't see a need to raise it up if you like it low you will be fine just go with a +42 off set wheel, and a 205/40/16 tire, and you shouldn't have a problem
tonyM
caca poopoo
i love camber,screws yer tires up but actually serves a purpose if you road race.
if you look at some of the pro cars they have camber like a mofo, but if you dont road race its pointless.it can be fixed with a kit but you cant really slam it with 16s unless you take the wells out. also if you plan to ride with alot of camber its a good idea to put a strut tie bar in.
theres my 2 cents
slambed_civic
well imagine a civic on stock 13s slammed... thats gotta be on the ground! camber is bad especially when you have a 40 series tires because theres only so much sidewall to roll in turns. so raise it up a lil, roll your fenders, and put some meat on the ground.
antivic
its all about VTEC!
just to give u guys the 411 on how low i am...its scary being behind a stock civic and my hood is like under there plates :P...yes yes my buddy club is fracked up =[
slambed_civic
and you dont see any reason to raise it up?
antivic
its all about VTEC!
lol hell yea i do...i don't like it that low rofl but the coil over thing won't budge rofll =]
slammed_93_hatc
BLAAAAAAAAAA you not low you have a f**kn huge ass front bumber, and minior camber (less than -3) doesn't not eat up your tires. ahahhaaha i still can't get over the fact that you think you slammed with that huge ass kit that body kit is most likely 2 or 3 inchs lower then your stock bumber.
aaaaa what ever im gone i refuse to help ice hot stunna ricers like you
