i need help 2000 civic d16y5 turbo any one help
hondasport
so i have an 00 civic with d16y5 simi built running t3-t4 turbo on i think p28 ecu just got the car and its all kinds of f*** up some of the pins on the origanal ecu plugs came out so i need a diagram my cel is on codes 4 and 14 so crank position sencor and iacv wich is bad i need to know what wires to change the 5 wire wideband o2 to the 4 wire o2and i have more question shortly
AlaskaB16
DOING WORK!
It's possible those pins will need to be pulled so I wouldn't just go plugging them in willy nilly until you know what they are. Look at your ECU and double check what it is. Did you just buy this car? Do you know if it's tuned correctly? Open it up and be sure it's chipped. Might even be wise to retune it if you can't verify the tune that's actually on it. I think I have a base tune for that motor w/turbo on my other computer which could help you in a pinch if your car goes down.
As for the info you're asking about, this is probably it. Good luck :thumbs up
http://honda-tech.com/showthread.php?highlight=wiring+sensor+o2+hx&t=2145030
