i seriously need advice...pulling my hair out
Brennan
is there any threads on putting a jdm d15b obd1 into my 6th gen 98 civic? (obd2) Im getting a bunch of different ways and im not sure what the easiest route is to go... do i convert to obd1 and change the computer and use a d15 wiring harness or do i stay with obd2 and use the same computer and swap everything over? and if i stayed with the obd2 what do i do about the crank and knock sensor...someone please help....i need my car back
Konig16
Use the OBD2 harness just buy a jumper that converts the OBD2 ECU plug to OBD1 so you can use the ecu intended for the motor. U will also have to do some wiring or buy a OBD2 to OBD1 plug for the dizzy as well. There are a few other things as well injector plugs as well as alt. plug will be different. just cut the plugs off the OBD1 Harness and use them to replace the plugs on the OBD2 harness.
