I've done some research is this a good build-tuner toys rods, vitaria piston, Orm bearings, shimmed and ported oil pump, arp head studs,3 layer head gasket then turbo kit said it should put out 300whp what do you think.
first things first.. how many hp do you want to make? after that search what will be the best parts to get ur botton ready ( always build it for more than your going for) you will need a good cam, ecu, maybe valves and springs + retainers.
vitaras are good but you will also need rods....
im sure ppl can help just be a little more specifit
you forgot injectors and if its a kit then it should come with the turbo and mani fold and oil lines but then you also need the intercooler and hardpipes and hondata or some form of it. theres a lot more to it then some think.
