Mr.Cummins
Me, of everyone in this blessed world has bought a Honda...
Being the hardcore BMW fanatic i am, this is a very unlikely situation...
This is my B20 build project...
The car is a Honda Civic EJ8 1997 model year, originally had a D-series motor...
Final results will probably look something like this;
What i already have;
-Honda B20B block
-Eagle con-rods and crank-shaft
-SRP pistons 12.5:1
-ARP conrodstuds (OEM Eagle)
-ITR ARP headstuds
-Cometic MLS head gasket
-ACL bearings, both main and conrod
-New B16B head
-B16 22T waterpump
-ITR timing belt
-B16A2 oil pump (do i need to upgrade?)
-Magnetic Oil-Drain plug (for the break-in, but i'll probably leave it in)
-NGK V-power BKR7E spark plugs
-P28 ECU og 310cc injectors
What i'm waiting to arrive from USA:
-BuddyClub Exhaust headers
-Skunk2 Pro Series Intake Manifold (307-05-0280)
-Skunk2 Alpha 70mm ThrottleBody (309-05-1050)
-Skunk2 Racing Mega Power Cat Back Exhaust System (413-05-2000)
-Crower Stage III Camshafts (BC0023)
-Crower Valvesprings (BC0020)
-Crower Oversized Valves (BC3022 & BC3023)
-Spec Stage 2 Kevlar Street Clutch (SA262)
-Spec Lightweight Flywheel (SA86A)
Future plans include:
-AEM Ignition system (Induvidual Coil on Plug)
-AEM Fuel Rail
-AEM Fuel Pump
-AEM Standalone
-Grams 550cc injectors
I have a OEM B16A2 gearbox to fit with this, but i'm looking to get a S9B tranny from a British B18C6 Civic (VTi)
Both because it has LSD and a higher final drive than the B16A2 tranny... (4.26 opposed to 4.40)
Also looking to buy a block guard to help with the 10.000rpm
Should be able to turn 12.000 if i sleeve the block, right ?
Any hp guesses are welcome and suggestions are welcome too...
I will be posting pictures once i start putting things together...
-Honda B20B block
-SRP pistons 12.5:1
-ITR ARP headstuds
-New B16B head
-B16 22T waterpump
-ITR timing belt
-AEM Fuel Rail
-AEM Fuel Pump
-AEM Standalone
