Identify proper wire harness required
CivicGil
I wanna fix the wiring to the driver side door and the passenger door. I would like some help in identifying the proper harness number needed. The issue here is the connection that goes from the door to under the hood(i think its the female connector) was corroded and removed. they spliced all the wires coming into the door to the harness thats in the door. So i need the harness for the driver side door and passenger side door as well as the harness they connect to. Would greatly appreciate any info. I have the manual and looked through but im having trouble figuring out which harness it is.
HeX
Authoritah, respected.
You can look up the part number at any of the several online OEM parts stores, such as MajesticHonda.com or HondapartsUnlimited.com. Hoewver, keep in mind they'll be pretty expensive even through those resources, so its best to pull them at a junkyard. We had a member recently go through this, so search for that thread too.
CivicGil
thanks for that info
