Identifying Boost Problems
Inigo Montoya
powered by boost
#1 -- LACKS POWER
Dirty air cleaner
Clean or replace element according to manufacturer's recommendations
Restricted air duct from compressor to intake manifold
Remove restriction or replace damaged parts as required
Restricted intake manifold
Refer to engine manufacturer's manual and remove restriction
Air leak in feed from compressor to intake manifold
Replace seal, gaskets or tighten fasteners as required
Air leak between intake manifold and engine
Refer to engine manufacturer's manual and replace gaskets or tighten fasteners as required
Foreign object in exhaust manifold (from engine)
Refer to engine manufacturer's manual and remove obstruction
Restricted exhaust system
Exhaust manifold cracked, gaskets blown or missing
Refer to engine manufacturer's manual and replace gaskets or damaged parts as required
Gasket leak at turbine inlet / exhaust manifold joint
Replace gasket or tighten fasteners as required
Fuel injection pump or fuel injectors incorrectly set
Refer to engine manufacturer's manual and replace or adjust faulty components as required
Engine valve timing incorrect
Refer to engine manufacturer's manual for correct settings and adjust as required
Worn engine piston rings or liners
Refer to engine manufacturer's manual and repair as required
Burnt valves and / or pistons
Excessive dirt build up on compressor wheel and / or diffuser vanes
Clean in accordance with details given in the appropriate Holset publication
Turbocharger damaged
Find and correct cause of failure, repair or replace turbocharger as necessary
Inigo Montoya
powered by boost
#2 -- BLACK EXHAUST SMOKE
Dirty air cleaner
Restricted compressor intake duct
Replace seal, gasket or tighten fasteners as required
Gaz leak at turbine inlet / exhaust manifold joint
Inigo Montoya
powered by boost
#3 -- Blue Exhaust Smoke
Dirty air cleaner
Restricted turbocharger oil drain line
Restricted engine crankcase breather
Refer to engine manufacturer's manual, clear restriction
Turbocharger bearing housing sludged or coked
Change engine oil and oil filter, overhaul or replace turbocharger as required
Inigo Montoya
powered by boost
#4 -- High Oil Consumption
Dirty air cleaner
Steven.
Formally Green 91
ive seen this somewhere before
Inigo Montoya
powered by boost
#5 -- "Noisy" Turbocharger
Air leak in feed from air cleaner to compressor
Gas leak in ducting after turbine outlet
Refer to engine manufacturer's manual and repair leak
Inigo Montoya
powered by boost
i saved it (thank god) and cant find the link.
# 6 -- "Cyclyc sound from turbocharger"
Inigo Montoya
powered by boost
#7 -- Oil leak from compressor seal
Dirty air cleaner
Inigo Montoya
powered by boost
# 8 -- Oil leak from turbine seal
