ughmas
Hello everyone, long time civic owner first post, would love some help with this issue, driving me nuts!
1998 Civic DX coupe all stock 5 sp
The story/problem:
Was driving fine one day, sitting at a red light in neutral, Car throws a CEL, idle starts going crazy (bouncing like its hitting a limiter (baw baw baw).
Pulled over, turned car off for 10 seconds, started back up, CEL still on but car idling fine now.
Same thing happens again if i let it idle for 20+ seconds starts going crazy again. Have to turn car off to fix it.
other symptoms-
if idling and press the accelerator breifly, when the rpms drop back down the engine skips when it hits bottom
slightly rough shifting due to weird idle
Went and got CEL read, P0505, suspected dirty/faulty IACV, and was told this is most likely the issue.
Took apart IACV, it was pretty dirty, cleaned with carb cleaner and toothbrush, got it looking like new, let air dry, re-installed and cleared codes.
On first startup after doing this car was running good, but soon the same thing happened. figured it went bad.
SO I ordered a new IACV, installed it, cleared codes.
first startup car idling high, it slowly settled down to where it was supposed to be, idling perfectly, let sit for a few minutes still idling good. Drove around for 20 minutes or so car running PERFECTLY, idling good, shifting smooth, smile on my face i think i have it fixed.
Get back to driveway, sit idle for a minute or so, CEL comes on idle goes crazy again baw baw baw s**t.
-Checked for vaccum leaks, none whatsoever, checked for air in coolant, none.
-When the IACV Is UNPLUGGED (before startup or during idle) it does the problem IMMEDIATELY
Im thinking it might be the TPS, am I missing something? I've searched the internet high and low.
Thanks
The story/problem:
other symptoms-
Thanks
