idle problem
civicracer03
I just turbo charge my civic. At first it idle ok and then it later started to have a pause in the firing. We check the fuel, timing, injectors, distributor, spark plugs, compression, and the only thing left is wire harness that may have a short. What do you guys think.
Phantom Civic
Never Satisfied
It may be a vacuum leak. Check/replace all of them.
civicracer03
i checked that too. I cap off all the vacuum ports. Its been 3 weeks without boost or vtec i dont think i can go on anymore
forcdincivic
Needs More Snail
Hey i just turboed my civic too, im having the same problem it sucks....idk how to fix it, i posted a thread aboout this too and they had a few things to say check it out
civicracer03
I did some more testing and cylinder #1 aint working for me. i disconnect the wire and the idle doesnt change and i cant go above 3,500-4 rpm. I checked the wire it has spark, changed the injector, and check the voltage on the injector wire 14volts. what else can i do?
