If it's not one thing its another...
greenlx777
BigRed is Dead
Talk about bad luck...
today i noticed that my drivers side rear view mirror was a little crooked, so i decided to fix the damn thing
So i remove the small triangular panel on the inside to get at the screws, i start removing them, but one was rusted like crazy, so instead of first spraying it with some grease, i just turned the damn thing, and SNAP...it broke off
so i was like "s**t" i cant just leave it hanging there, so i removed the whole thing, and took it apart, i had to make my own screw to fit in its place, so i did and drilled it into the body
then when i put the rearview mirror back on, for some reason the window had difficulties rolling up and down....so I was like "what now"...
turns out the hole i drilled, was too close to the sleave were the window slides up and down.....
so finally i loosen the screw, and grease the inside of the sleave so everything would work smothely...
in the end, what was supposed to take me 3 minutes, took me an hour............
At least they make these parts, in a way, that if they break, you can fix it yourself, imagine if i went out to get a brand new rearview mirror...
ben
excommunicated
at least it only took a hour... If I were doing it, It'd have been a 2 day project! lol
J-Bird
I-VTEC Daily
Could have been worse, it wouldn't be working on the car if everything went according to plan.
rollinj86
Hit the vtec
always happens to the best of us life sucks.
yomuppet
Hell, you got off easy. My kill switch ended up taking me like 4 hrs when I put it in, then another hour when my shoddy solder job failed ;)
greenlx777
BigRed is Dead
Damn!!! friday the 13th i didnt realize that, thanks for noticing
