Im here to learn as much as possible!
RicerEK4
hey guys i just got my 1998 dx sedan and im looking to learn evertthing there is to know about building hondas. I have a basic knowledge but im trying to learn more =)
Shiznit
Stickin it to the Man
:welcome:
Shiznit
wow big ambitions, good luck with it and keep us posted. show us some pics of your car.
CivicForLife
Yooo I also have a 98 dx but mine is a coupe. We could still learn alot together since we pretty much have the same model. :word:
Cooper76
Welcome to the site! I have a 98 EX sedan and I just did an LS turbo swap in it last week. I'm not gonna lie, I had a lot of help to do it too! LOL.... Good luck with it!
Good luck man and :welcome: !
I also have a turbo LS swap in my 97 LX sedan, and I looooove every minute of it. As with the other guy, had a TON of help with it too.
Cooper76
I EFFIN LOVE IT!!! I've owned this car since it was new in 98 and this swap made it into a completely different driving car. I'm new to swapping civics and modifying the drive train in them and have not had a lot of experiences riding in turbo'd hondas. But it pulls harder then any other one I've ridden in.
I had my first race the other day too. LOL... I'm sitting at a light here in town and a guy in an old IROK Z started revving, LOL I couldn't resist it! I smoked him! We pulled over and talked for a bit cus he couldn't get over the fact that he was just beat by a four door civic! You should have seen his face when I popped the hood!
emerican
About it being cheap im not sure i never done one but heres a post from another honda forum.
If any of this is wrong people who have done this please correct me, but just trying to help the guy out
LS block = 400
B16A head = 550**
Hydro tranny = 650 *GSR/SIR
Clutch = 300
Linkage = 100
Axles = 250
Engine harness = 150 *depends on OBD1 or OBD2 costs may be higher
ECU = 250 *stock GSR or programmed P28
Pistons B16A = 25/ea *cannot use with aftermarket rods.
Rings 81mm = 20/ea
ARP rod bolts = 45 *for the LS rods if you are planing on using them.
Pistons aftermarket = 425/set *comes with rings, can use on stock rods if machined.
Rods = 350 *Eagles. They are the least expensive good rods, the factory LS rods will NOT handle revs over 8000 stock, and not over 9000 with ARP rod bolts. Don't cheap out here, these are the heart of your engine. Failure here can result in all your money lost.
Rod bearings = 64
Head gasket = 55
Other misc gaskets for install = 100 (oil pan, camshaft, intake manifold, exhaust manifold, water pump, oil pump, etc, etc...)
**Assuming the head came with intake manifold, dizzy, injectors, t-body, etc, etc.....
I busted out some reciepts for machine work and labor costs from my stroked/bored GSR engine.
Press pistons on - 60
Bore block, torque plate - 120
Balance crank, pistons, rods - 200
Shotpeen rods - 80
Port and polish head, intake manifold, exhaust manifold. All gasket matched - 950
Clean and tank head and block - 100
Now, I did all the assembly myself, so I saved major $$$$ over having someone else do it for me.
So add it all up, then figure about 20% more just in case. You never know what you may run into when doing something like this.
Cooper76
I won't lie, I nearly stole my drive train! I paid $2000 for my entire set up installed. The engine is built with Eagle H beam rods, ARP bolts and studs, forged pistons, block guard, 8 lbs fly wheel with a stage three clutch. It's running OBD 1 and I have a used T3/T4 turbo set up on it. I bought it all from my mechanic with just over 2000 miles on it from a wreaked car that he had built for a customer.
emerican
I knew i rememberd your username for a reason cooper76 i remember your thread about purchasing that ls vtec. Im glad to hear iits going good and you defintly did get a steal and a warrenty.
Cooper76
Yeah, I thought it was a ls vtec, but I was wrong. I guess I jumped the gun cus I was too excited with the notion of all that s**t going into my car! LOL... But I still got a hell of a deal and yes, warranty too! When the budget lets it happen, I will do the ls vtec head swap.
Just keep looking, deals can be found.
