injecotor problem help please!!!!
AjPetrarca23
i bought these injectors not knowing if they needed resistors and i put them in today as a finish to my turbo install and the car just kept turning over and would not start. it started up with my stock injectors in tho. im not sure if i need resitors or if they are just dead injectors
2slo4u
wait4me
what kind of injectors are they? is your ecu chipped with a basemap and ready to tune? i dont think you can just put in injectors and have them work right away
TiiM iiS l3eAsT
Scamming Piece Of s**t
hmm...i would go get them tested somewhere.....sounds like they might not be working....
codyllee
why didnt you buy dsm 450cc injectors? they are around that price. I would not doubt it if you need a resistor box
2slo4u
wait4me
find out if they are saturated or peak and hold..saturated=no resistor box and peak/hold=resistor box required..check the for sale section, some forums close to you, or check the junk yard for a resistor box..when/if you get one check back here and search on how to install resistor box..or just pm me =)
AjPetrarca23
i found out that they are saturated. and the name is T.R.E Performance. 440cc for honda B-Series. i have a 97 civic so i wired up some obd1 clips to they will plug in. is there a certain way to wire the the new clips. i just cut off the old clips and spliced them right into the 2 wires. or are the injectors not working because they are for a b series and mine is a d16y8. i also have a obd1 chipped ecu.w/ conversion harness hooked up.
2slo4u
wait4me
i dont think it matters if its for a b series for d series..as long as it fits on the fuel rail and the injectors/o-rings fit the manifold, it should work..i think there are like red, blue, yellow, brown wires right? just connect the color of the new clips with matching colors..i think they are the same, im not sure if having a fuel pump would matter but do you have one installed?--im starting to think the injectors are no good though, get them checked
2slo4u
wait4me
np..hopefully everything goes smooth for you.
