No you do not need a tune for an aftermarket intake.but im changing my stock intake to a cone with a aem pipe when i do that do i have to tune the car beacuse that is what i was told?
You could reset the ecu if you want.
just stick it on and what leave the plug unpluged?lol
no, you dont, just stick it on.......
What plug?just stick it on and what leave the plug unpluged?
there is a plug that plugs into the stock airbox but aem pipe and come there no spot for it ?What plug?
Sent from my Nexus S using Tapatalk 2
k i think i understands i basicly have to somehow pluge that plug in the aem pipe?You have to drill a hole for the plug and get a rubber grommet to hold it in place.
This is a HORRIBLE idea. Can you say heat soak much?First off, please use paragraphs, capitalization and punctuation.
If I understood correctly, you want to know if you could remove the piping altogether and just put the filter onto the intake manifold/throttle body?
You can, my brother did that on his D17. It would give you a little more low end power, I mean just enough to feel it, not that much, but you would lose power on higher rpm. Not bad if all you do is drive in downtown/city a lot lol.
But you still need the plug because it measures temperature I believe, correct me if I'm wrong.
