Originally posted by 98 SIR II
it is hitting the piping. the heat shield isn't on there anymore. but i think i need to see if i can have a shop rig it or see what the heck the problem is. but if you have any ideas let me know. my mechanic did tell me that the shifter is to short so that is why it is hitting the piping. But i don't know what he meant by that. so i don't know im stuck
You gotta
read my thread . I had exactly the same problem.
The thing is hitting, not because "it's too short" (BS answer) but because the distance from the ball joint of the shifter to the linkage hinge is too long (compared to stock). This pushes the shift linkage down (doesn't affect shifting the tranny) but... it pushing it down low enough to hit the exhaust pipe.
In fact, it's not actually the hinge that hits the pipe... it's actually a stupid counter weight that welded to the stock shift linkage.
I think the only solution to this is to weld cut the counter weight off, and then weld it back on in a higher position.
Or you can lower your exhaust pipe (and give up ground clearance).
Either way, it's a pain in the ass unless you have full access to a nicely setup garage.
