I get my short shifter tomorrow and i wanna install it. Anything i should know? Does anybody have like quick steps on what to do....just remove the cover and knob, etc and then undo some screws? never really looked under there before. thanks
it took about 45 minutes, which included getting my jack stands set up, jacking up the car, removing, and installing. not too long, and easy as hell in my opinion. thats a good deal on that link....i should have done that!! i need the shift knob now...zoops said:How long did it take to install all together? Also, does the short shifter work fine just by itself? Or do I need bushings, as ncluded here: http://www.robearracing.com/pd_skunk_2_short.cfm
didn't drop the exhaust, although it would make it easier for instaling the short shifter, but more time consuming. no problems except the fact that it rubs the exhaust pipe barely so when you gas a little bit the shifter vibrates and rattles sometimes but i broke one of my bushings so it has a lot of play, that could be it!LatinEM1 said:have u had any problems with it? did u have to drop the exhaust??
you'll see when you drop your old one...you just replace the old ones with the new ones.LatinEM1 said:Hey shane, how do you use the bolt that comes with the shifter? im getting mine in a couple of days..
