So today i decided to buy a tach for 50 bucks, since my car doesnt come stock with one. I read up on how to instal it prior to buying it and i thought it wouldnt be that bad. Now i have it mounted, grounded, powered, and lit up when i turn on the lights. Now i am left with the signal wire.. I tried it on my ignition coil (negitive terminal), but when i turned the car on it just went up a little bit then dropped back to zero.. while i was reving it. I also checked to see if it was on 4 cylinder. which it was. Next i realized that people put the signal wire into the Blue wired 2 pin connector thing on the drivers side behind the shock tower. I tried that.. nothing at all.. I need some help here, and i havn't had any luck with searching.
Thanks
Thanks
