integra dashboard
ner0x
SOHC MY DOHC
does anyone have a tutorial for putting a integra dashboard into an eg coupe ? im planning on doing this myself and i just want some reasurance and help. anything would be appreciated
Destroy
its gonna take time and effort to pull it off.....knowledge in wiring and fabricating....or you might just cut corners like everyone else does, which ends to creaking and vibrating dash to lights not working....i say 1 out of 10 people pull it of correctly....oh yea, wrong section dood
NOFX
I'm NOT eran!
I went to Honda-Tech.com and searched the archived content for "Integra dash" in the EG/del Sol section. =)
PDM on Honda-Tech said:
-CLICK HERE FOR ORIGINAL THREAD-I thought i would post about my experience installing an integra dash into my friends 92 Civic SI. Theres quite a bit of info on these boards but was really hard to find when so many people were asking the same questions over and over again. IM going to post on my experience and hopefully it will answer some questions down the road.
Putting the actual dash in: My friend was lucky enough to find a dash that was previously in a civic so I cant really tell you what is needed (as far as trimming or whatever goes) but its not difficult from what i was told and some people here mentioned having to make custom brackets or whatever which isnt needed.
Wiring: The dash didnt come with an integra wiring harness so we had to look around the boards and luckily we found one. We printed out the diagram listed on honda-tech ( http://honda-tech.com/zerothread?id=94431 ). We took the civic harness and cut the 2 gray plugs that connected to the cluster and cut the 2 blue plugs off the intergra harness to be used on the civic harness.
This is where we ran into a problem. Looking at the integra plugs that go into the cluster we noticed some of the colours didnt match the diagram and some slots which were listed as empty had wires in them and slots which had wires in them were listed as empty. After a lot of thinking and screwing around we looked at the back of the cluster and could tell by following the circuits which slots were being used and which werent. Luckily we noticed it matched up exactly to the diagram on this site. We ignored all the colours of the wires and focused on what slot served what purpose and we had to poke some wires out of the plug and move them over to different slots.
After we fully converted the 2 big plugs that left us with one small plug that was still from the old civic cluster. We asummed since no ones mentioned this third small plug (3 wires) that maybe it just snapped right in? Wrong, we looked at the same plug from the integra harness and noticed it had the same amount of wires and the same colours but the plugs were different. We just cut off the plugs and swapped them and wired according to colour. We snapped all three plugs into the back of the cluster and bingo. Absolutely everything works perfect on the cluster and never ran into blinker problems that some others have mentioned.
As for the rest, the integra Climate control plug snapped right into the old civic one and works perfect. The clock plugs are different but have the same amount of wires and same colour. Just cut the civic plug off and swap it with the integra one and wire according to colour. We also had a stock integra cd player which looks pretty clean in the dash and luckily both plugs (civic and integra) were the same and required no cutting. The civic dimmer plug connects to the integra dimmer but started to smoke up really bad once we turned the car on ( after reading around the board we werent the only ones) so we decided to leave this one alone for now. We have yet to wire up defroster, hazards, dimmer and sunroof. We werent able to find any info on wiring these things so we just left them for now. Other than that everything on the cluster works perfect and lights up just like it should.
ABSOLUTELY make sure to have extra fuses around. We ended up blowing quite a few and having to look for fuses during the install was really time consuming and made things a lot worse than they should have been.
Door Panels: So much talk about door panels on these boards. We just used the stock eg panels. We decided to steer away from the melt the panel plastic and close the door trick. It seemed a little too ghetto and we didnt want to ruin the vinyl or the dash (not saying it will but we dont want to take any chances) Instead we peeled the vinyl off the door panel revealing only plastic and cut where the dash was touching the panel and kept cutting until the plastic was shaped perfect around the ends up the dash. We pulled the vinyl back over and put the panels back on the doors. Is this method better than the heating up method? Not really but we noticed the vinyl didnt wrinkle as much at the parts hidden by the dash. When the doors are closed the panels look flawless and you cant tell theyve been hacked at. They also look a lot better when the doors are open compared to the heat method (probably because the vinyl isnt as wrinkled).
I will post pictures some other time when im able to take them. In the mean time if anyone can explain how to wire up hazards, defroster, dimmer and sunroof please do as I am unsure how to do it.
JDMH22HATCH on Honda-Tech said:
Here's some info on the wiring from Brandon aka Poison
GSR Dash into EG wiring information:
Using the GSR harness (which I have done), it's very simple to get your dash 100% working.
You can use the GREEN and BLUE plug, which plug right into the Civic fuse box plugs.
HOWEVER
The grey plug has additional pinouts on the Integra dash harness and cannot be used. Just retain the Civic grey plug and match the pinouts.
I am currently making a JPEG diagram for this -- will be up soon.
ONE THING, your turn signals will not work.
Why?
This is why:
The power wire going to the Integra hazard switch is the Yel/Blk wire, where-as the Civic hazard switch is the YEL wire.
Just simply take the Yel/Blk wire from the Integra harness (which is an unused wire from the grey plug), and splice that into the Yel wire on the GREEN plug (the middle pinout YEL wire.
Kaboom -- done.
Other than that, just take your time. I used the civic dash mount and just used my dremel to trim out behind the guage cluster and the inside by the dash mounts. Here's some pics of mine in my 4-door. Everything lines up great except for the inside where right where the door closes towards the body and still its only a small gap
Also found these listed in a thread on H-T. Granted I didn't review all of these links.
http://www.honda-tech.com/zerothread?id=504396
http://www.honda-tech.com/zerothread?id=285567
http://www.honda-tech.com/zerothread?id=170977
http://www.honda-tech.com/zerothread?id=458450
http://patriot.net/~merritt/tech.html
http://honda-tech.com/zerothread?id=285567
http://honda-tech.com/zerothread?id=486442
http://honda-tech.com/zerothread?id=411500
http://honda-tech.com/zerothread?id=401025
http://honda-tech.com/zerothread?id=184743
http://honda-tech.com/zerothread?id=139148
Hope some of this works for you. There's LOTS more on Honda-Tech. =)
deftone
^^^^ what a gay car
Mr. Lin
Admiral Ackbar
ahhha... that's harsh talk on your own car =)
Ninefivejiggaja
Milano Em1 Guy
yeah theres a think on ht its pretty cool i was thinking about doing it but then i got an EM1
ner0x
SOHC MY DOHC
deftone, ur car is the shiit. =] any advice??
and thanks for the help. looks like its going to be a challege, and im a n0000000000b when it comes wiring and all that other krapp. o well, i'll show you guys the ending results
42Steps
Welcome my son....
Why dont you leave it as is if you are a noob to wiring.... There is better stuff you could be spending your time on.... IMO...... :???:
ner0x
SOHC MY DOHC
nooo.. i want an integra dashboard! i dont like the eg dash, im not used to it. lol
deftone
try and find someone who knows about hondas that does stereo install work. you should have all the info. you need to do it from all those links on HT
ner0x
SOHC MY DOHC
yeah, i've been reading everything. wow its a b***h! i'll have a couple experianced people helping me though. but what i am worried about is: the dashboard mounts (becuz im still not sure where 2 cut..) the steering colum install, and the ac... idk im still kinda confused, im print all this stuff out, wish me luck. i like big projects.
NOFX
I'm NOT eran!
Good luck! Post pics later. Btw, be nice if we had a clear write up for a how-to. ;) *hint hint*
mrsatisfiher
I am finisihing up my dash conversion
I am in the process of finishing up my dash right now its not hard buts its very time consuming if u were to take the wire harness that behind the dash that plugs to the hazard, defroster, etc then your work will be a breeze for me I used all the integra wires right from the engine bay to the whole fuse thing. the reason I did that becaure I also hook up power window, mirror, and lock. and for fabrication wise I have to cut the most of the plate that the steering wheel attach too to fit the cluster in nicely if u need some advice let me know
ner0x
SOHC MY DOHC
i will for sure need some advice, im going to use the integra harness, cut my door panels and reupholstered them, i dont want to do the hair dryer thing because it wont have a clean look. but i'll be sure to take lots of pixxxx = ]
mrsatisfiher
yeah I took a lot of pics but its pretty much like the other guy liam thread. for me I cut a little of the dash too and I cut most of the steering wheel support thing I have to wait until the weather gets better here then hopefuly I could finish it in a few days. be be stupid like me and have to take it out for like 3 times. u should test out all the function as u go meanning that once u put the dash it check to make sure all the lights, signal and all of htat stuff works before putting the dash in
ner0x
SOHC MY DOHC
yeah, i dont want to make many mistakes in doing this. hopefully when im finished, everything works and it doesnt rattle or anything... lmk on aim or something if you need me to host your pix, - wick3dganzta-
mrsatisfiher
my screen name on aim is mrsatisfiher I could chat with u and tell u what to do also the reason its taking me a long time is because I am hooking up my remote start and my alarm also. to be honest with u if were to do one for someone else its will take me no more than a day
ner0x
SOHC MY DOHC
thats awesome, i think i got the dash today... but not sure i'll know 2morr. i'll im you 4sure 2morr
honda man
that is true if u donr really know about wireing that much i wouldent try it i would have someone that know what they are doing do it instead of taking a change of messin something up on accadent..
